27 "iMac (2011) stops booting with Gray Screen
Hello everybody
I have a gray screen problem with a second-hand iMac and I needs your help. The Mac loading bar will remain at about 2/3, shortly thereafter, the screen is light gray. When booting in safe mode, the loading bar fills up to about 4/5 until the gray screen pops up. The classic "first-aid" tips I have already through, ie I have already tried the following without success:
- External peripherals suspended
- Safe boat
- Reset VRAM (PRAM)
- Reset SMC
- RAM swapped
- Diagnostics performed (only displayed the fan error)
- OS Repair over LAN
- HDD exchanged (just for fun, then point 5 repeated)
- Boot up from external HDD with an installation of High Sierra
My assumption is I'm facing a hardware defect since even a boat from the external Hard disk was unsuccessful.
What would be sensational would be a further tip, if there is still a possibility of a software problem, or a limiting tip, when it comes to a hardware component to exchange.
1 Comment
The fact you can get into Safe mode as well as Diags tells me the dedicated GPU has failed.
by Dan
