Model A1502 / 2.4, 2.6, or 2.8 GHz dual-core Intel processor / Released October 2013
552 Questions View all
Mac runs great but has a VFD002 error when I run the diagnostic tool
I bought a late 2013 retina macbook pro Everything is working great. The only concern i gave is when i run a hardware diagnostic. it says there MAY be an issue with the display and gives me the error code VFD002. Should i be concerned? or is nothing. It's a late 2013 retina.
2 Comments
Hi,
I have the EXACT same issue with the same model MacBook Pro. Runs great but VFD002 in the AHT.
Did you find a resolution?
by
I have the same issue on the same mb model..
by
Add a comment
1 Answer
Most Helpful Answer
The error: VFD002 implies there may be an issue with the display.
Score 1
2 Comments:
Yes i saw that but my display works just fine i have some glitches when i see a fullscreen youtube video.. is there any solution?
by
I would check the internal displays connection. Follow this IFIXIT guide thru Step 6 then jump down to Step 11: MacBook Pro 13" Retina Display Late 2013 Display Assembly Replacement. Inspect both the cable and the connectors connections do you see any corrosion? If so carefully clean it. Otherwise the issue is within the display assembly its self.
by
Add a comment
Add your answer
Griffin Gardner will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 2,119
