Unable to create Fusion Drive
I purchased the enclosure to add a second hard drive to my late 2011 15" Macbook Pro and I wanted to setup a Fusion drive using my 500GB SSD and another, larger capacity HDD. No matter what drive I drive I tired using in the optical bay, I kept getting errors creating the Fusion Drive (could not unmount because the drive is in use, input/output errors, etc).
I originally had the second drive as a Time Machine backup disk (which worked fine) but that drive was starting to fail so I thought I'd migrate to a Fusion set up on the recommendation of a colleague.
Has anyone had ANY success doing this and if so, how did you fix it? Is this just a limitation of using a hard drive connected to the optical drive controller?
