GPS location works, turn-by-turn navigation does not
I have been having an issue with my iPhone 6. The turn-by-turn navigation does not update when you stray off of the route in any GPS app (maps, waze, etc). So far I have attempted the following:
1. make sure location services is turned on and app is allowed access
2. uninstall/reinstall navigation app
3. factory reset iPhone
4. sent for authorized battery replacement service - battery is now brand new
5. replaced wifi F antenna (from ifixit)
Everything else works perfectly fine. Wifi signal is strong. Prior to replacing the F antennae, the GPS location was weak - ie there was a large blue circle of uncertainty instead of a small blue point. After the F antenna replacement, the signal is strong, and it is correct. GPS location does not drift or appear weak. I downloaded a google map for offline use (LTE is turned off since I have switched to another phone during the repair process) and drove around the block - the GPS kept my position accurately the whole time, but turn-by-turn navigation still fails to update, even when I am significantly off-route (0.5 miles at least).
I am completely at a loss for what to replace next. After the factory reset and battery replacement, I basically ruled out a software issue, right? There's no way that turn-by-turn requires LTE right? I tried the same experiemnt with another phone's hotspot connected and it did the same thing. What should I try next?
