Model: HX9300 Series The Philps Sonicare DiamondClean Series can be identified by its model family number: HX9300. All HX93xx models are the same toothbrush. The third and fourth number determines the contents of the box. The numbers after the slash (/) determine the color of the handle.
1 Questions View all
HX9360 can't turn on
I measure the battery about 3.8V.(F1 /R6 point).So I think the battery is fine.
But I push the button can't turn on it.But put into the cup can charge the battery.
So how do I to check the board or more action?
thanks
Add a comment
Free shipping on all orders over $100 or containing a Pro Tech Toolkit!
Browse Our Store
Most Helpful Answer
swat1230 your voltage maybe fine but it is not a good indication of your battery being okay. It is possible that your battery simply does not hold enough charge to supply the demand. I'd start with a new battery first, then re-evaluate. Check your switch circuitry etc. with your multimeter.
Score 2
Add a comment
I'm having the same problem. Have you fixed it?
Thanks!
Comments:
I have also checked the switch circuitry, which is fine. Additionally I have also connected an external power supply with 3.8V. Unfortunately it didn't helped.
by
Add a comment
Add your answer
swat1230 will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 33
All Time: 568
