Start up chime every 3 seconds - Cannot boot
I tried re-installing High Sierra but forgot to wipe the HDD.
After rebooting and trying to re-install with a wipe, the imac turns on, plays the start up chime, then every 3 seconds later it will play the chime again. The screen is white/grey (hard to tell as the brightness seems to be all the way down)
It is not chiming every 5 seconds .
No keyboard commands work. It is like its stuck in a loop.
Tested other keyboards.
Any ideas on how to fix this issue?
Do you have a bootable external drive? If you do you'll need to use it to get your system to boot up. You'll also need a USB wired keyboard to get the bootup commands to work as I suspect you aren't even getting to the point in the boot process for the Bluetooth services to be functional.
Use the Option Key to gain access to the startup manager so you can select the other drive using the arror keys of the keyboard.
Let us know if you can get this far so we can walk you through the rest.
Reference: Mac startup key combinations
by Dan
Hi Dan,
I have tried booting from USB but it is like the imac doesn't register that any keys have been pressed. It seems to busy rebooting /chiming. The screen doesnt actually change or refresh though, just constant chimes every 3 seconds. I have tried various wired keyboards as well just in case they were faulty.
Thanks
by Gerard Hampton
Just so I get this right you used a USB keyboard?
by Dan
Yes, wired USB keyboard. Mac version and PC version.
by Gerard Hampton
Why were you reinstalling? What did you change? What was it doing that you felt you need to do a reinstall?
by mayer
Show 4 more comments
