The MacBook family was first introduced in May 2006 and replaced the iBook as Apple's consumer laptop.
4025 Questions View all
Why is 13" replacement LCD so dark.
Read similar questions but not sure it covered my situation. Basically dropped my A1181 Macbook which resulted in half of the screen going black. So I ordered a replacement LCD and it is extremely dim upon installation. Brightness adjustment has no effect. Is it possible this is a result of the inverter cable going in halfway or upside down? I've installed it with removing the top case. When I put in the old LCD I have the same half black screen, but it also is now extremely dim. I haven't put everyting back together so I don't think it is the result of a screw length issue. Ideas? Thanks.
Add a comment
Spread Fixmas Cheer
Get $12 off your purchase of $50 or more with code FIXMAS12
Spread Fixmas Cheer
1 Answer
Chosen Solution
It's not easy to reconnect the backlight connector to the inverter board socket so it's possible that the connector is not well seated in the socket. There's also another connector at the other end of the inverter board that connect to the logic board. Check this connection too.
If that doesn't work then maybe you have a problem with the inverter board itself or the inverter cable.
Did you check the brightness adjustment in the system preferences (monitors) ?
Score 2
Comments:
I will check both, I unfortunately put a little too much pressure trying to connet the inverter. Looks like the black strip/baord (?) under the hinge mount has come loose. I am now going to remove the top case to see what I can find out.
by
Add a comment
Add your answer
pete will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 2,015
