Released September 16, 2016. Model 1660, 1778 Available as GSM or CDMA / 32, 128 or 256 GB / Rose gold, gold, silver, black, and jet black.
2264 Questions View all
Unknown Diagnosis (iPhone 7)
iPhone 7 dropped dropped and worked however when it died it only charged to 3%. It was taken to repair shop where it I was taken apart and put back together and the screen showed saying connect to iTunes. I was given the iPhone, I changed the charger port, however it still showed connect to iTunes. When i connected to my pc with iTunes open nothing popped up however the iPhone charged. I disconnected the iPhone and it died so I went to charge it. When I came back 15 minutes later it would not turn on after hard resetting or force rebooting. Is this a logic board problem and where can I get this fixed?
Add a comment
1 Answer
Chosen Solution
If you have a repair shop around your area that specializes in boards you can get a rough estimate from them. Otherwise I would probably just get a new device if you can. Seeing how that it will go into recovery mode (connect to itunes), the only data retrievable would be through the cloud. Of course, this is depending on the specialist for logic boards.
good luck
Score 1
2 Comments:
So this can’t be fixed? It cannot be restored?
by
It may or may not be fixable. This just depends on which part on the board was compromised.
by
Add a comment
Add your answer
Christian Lapitan will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 56
