Won't power on, fan twitches when power attached, new logic board?
MacBook suffered liquid damage, looked like it was just keyboard, so was sent away for repair under household insurance. When repair company came to send it back it was tested again and failed to boot up. They suggested the logic board needed replaced. I was able to then get a claim for a brand new MacBook from insurance, and I had a recent backup of my old one so everything is fine really, I just feel that the old one might be possible to resurrect yet.
When plugged in the magsafe light turns green, then when I press the power button it turns to red/amber. Also, when the power cable is attached, the fan immediately starts 'twitching' spinning briefly then stopping. There isn't even a hint of anything else when the power butting is pressed. The battery indicator shows one green light, I know the hard drive works as I've had it out to check, there doesn't seem to be much in the way of corrosion on the top side of the logic board. It does look like the DC in board may have a bit of corrosion or damage to it. I guess my main question is could that apparent damage cause the symptoms I describe?
I've not been able to fully take it all apart yet, but if I do and there is obvious damage/corrosion on the other side of the logic board, is that possible to clean?
Any other ideas what might cause the symptoms as described - again, I guess I'm most interested in DC in board vs logic board. Possibly prepared to fork out for new logic board and replace it myself.
