Oddly similar scenario with my MacBook Pro - no solution yet . . .
Okay, I came across this exchange after my 13” MacBook Pro went dead right in the middle of loading the OS. I had been using it all day without incident until it had become very laggy to to the point of being almost unresponsive. I was doing research and had a butt-load of open tabs in Safari I assumed were drawing hard on the resources. So. I pressed the start button and held it until the machine shut off, then rebooted. Everything appeared fine until we got to the part of start-up phase where I believe the graphics driver loads and takes over the job. The screen went black and then immediately blinked to a state where the bottom half was white and the top remained black with some intermittent white lines and artifacts where the white and dark parts met. To be clear, that is how it has always behaved at that part of the start-up. Normally, right after the screen flash to black and white within a split second apple the logo and progress indicator return and then the log-in screen appears. This time the screen flashed and remained dark. When I looked I realized it appeared to have completely shut off. So I pushed the power button again. The MacBook Pro chimed, began to load, and then same thing at exactly the same point, appeared to go dead. This time pressing the power resulted in no response. No keyboard lights, no chime, no fan… nada. I follow the instructions for every scenario I find online about the issue, no change. When I reset the SMC, the light on the power supply changes to green then back to amber indicating the SMC resets but still no action or response when pressing the power button. So just in case, I connected it to power and allowed it to charge all night. This morning - no change. The MacBook Pro USB ports charge when I plug into them and SMC responds to reset commands but the laptop still remains dead.
A couple of other detaIls: The magnetic power supply and connector are NOT OEM. And after charging all night, the light indicator on the power supply never indicates the battery charge is complete. This is a brand new OEM battery that only showed 53 cycles when I looked at the system report this past weekend.
My next steps are going to remove the bottom panel and disconnect the battery and fan cable to see if that makes a difference.
6 Comments
I am having the same issue like you. No solution yet. This is third time I get. Last 2 times I tried PRAM reset and it worked. But this time no response from machine. Plz help with solution if you have any.
by Umashankar Harindranath Rao
Any update guys? I have the same issue and looking for answers
by promila.matta00
Umashankar Harindranath Rao & promila.matta00 - If your system is reacted in the same way you need to replace the logic board as the CPU and/or PCH chip has failed.
by Dan
This has happened to me last night with my pro retina 2015 . It’s very frustrating
by The City Cyclist
Same thing happened! Thought it was battery related, bought an ifixit battery and toolkit, 4 hours later, no change! I’ll never thought this would happen with a Mac!
by tonydavid
Show 1 more comment
