The March 2015 update of Apple's 13" MacBook Pro Retina Display, model A1502, features fifth-generation Intel Core i5 and i7 processors and introduces the Force Touch trackpad.
1185 Questions View all
Is it bad that my laptop fan comes on everytime I use it?
Within 10 minutes of me using my laptop, the fan comes on. It's not very loud, but I can definitely hear it. The fan doesn't shut off until I have closed the lid to my laptop.
I appreciate your thoughts!
Score 1
Add a comment
1 Answer
Chosen Solution
Being usually a quiet machine, although it's normal the fans get started after some usage I see here several options:
  • You use your macbook for fairly demanding tasks
  • You are a person very sensitive to noise and use it mainly in silent environment
  • Some undesired task is started up using consistently a high percentage of your processor.
In case the latter seems to you the best explanation, when fans start you can open Activity monitor you will find in Application/Utility folder. Select from menu to show _all_ processes running and see what's using most CPU.
That will give you a clearer picture on what's happening and might answer your question about fans.
Score 3
2 Comments:
To add to @arbaman great answer. You might also want to look at what the thermal sensors within your system are doing and how they are effecting the fan. This is a great tool for that: TG Pro
by
@danj Thanks for adding on further infos and help :)
by
Add a comment
Add your answer
Amanda_S_55 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 160
