Can I , and is it safe to add an on/off switch to my laptop battery?
So the main idea here is that i get better performance whilst plugged in.
I like gaming so I play a lot. I usually start playing when the battery is low so i can play and charge , thinking it's better for the battery to be used (charged and discharged) .
After playing for a while the battery gets full , and I want to keep playing with the same performance. So I came up with the idea to add a switch to the cables connecting the battery wires with the motherboard. So I can stop using the battery when it hits 100% and continue playing plugged in. And after finishing I would turn the switch on, connecting the battery with the motherboard and then remove the plug and continue browsing using the battery. But am afraid to try because i just got this laptop.
1 Comment
Hi i want to do the same with my laptop. How have you managed to do it? What kind of switch or circuit have you used? Thanks in advance.
by Alberto Einstannio
