Are the wireless cards for the 2009, compatible with a 2012 MB?
Hello,
I have replaced my 2009 C2D motherboard, with a newer 2012 I5.
Yes some things don't align but i worked around those and have everything secured and working, except the Airport/Bluetooth.
As you may know, if you look closely, the cables for the card to the motherboard change between 2009 and 2012. i was wondering if there is a cable that i can either make by cutting off the old adaptor and put the newer one on. Or if there is a cable that someone else made out there. Of course this wouldnt matter if the card and motherboard are not compatable. If that is the case, would there be a different wireless card to be a replacement in the same spot, or would i need to use the newer one that comes in the 2012 macbook pro. if i need to use the newer one, i will have to remove the screen glass to access and replace the old antennas as well.
Thanks to all for any feed back or more info.
