Water flooded my Mac ---Need to recover data in SSD 12+16 pin
Hello Experts,
Water flooded my Mac and spoiled my motherboard.
I put the 12 plus 16 pin SSD inside a similar Mac but it does not come up. I notice that some of the pins are also looking stained. Some say it can be read through Linux by mounting as /dev but I need another option.
Is there any way I can recover my data?
Best Regards,
Kingsley
Update (04/06/2018)
Dan,
I used Methylated Spirit to clean the pads. I don't know if its better than before. Can you confirm
the name of the chemical for cleaning gold/copper?
Or do you feel I could try it based on the picture
Thanks
Update (04/10/2018)
This is the back of the chip.
Thanks
Update (04/10/2018)
This is the back
6 Comments
Can you post some clear images of your SSD showing us the chips and the connector on both sides so we have an idea how bad it is.
Adding images to an existing question
by Dan
Looks better! the black junk is gone! But you didn't use a Pink eraser! You need to polish off the film thats still present. The gold surface still tarnishes as its not pure enough.
As to what I use is an over the counter metal polish "Twinkle" its a paste which I apply using a cotton swab (Q-Tip) and then I wipe off the surface with distilled water and dry it with a paper towel.
by Dan
I have used HCL diluted and it has virtually cleaned the surface. I would now either look for another Mac my spec or try to purchase the casing as recommended. I would send the result once I have done it. @danj , thanks in advance
by Kingsley
Do you mean diluted Hydrochloric Acid?? It's not something I would use here.
I'm not sure if the film residue will come off with it which is why I was pointing you to a mild abrasive (pink pencil eraser or metal polish).
by Dan
Unfortunately, I just put into another laptop and it didn't even come on again. Looks like the HCL has bridged the pins or so. What do you think?
by Kingsley
Show 1 more comment
