The DZ09 is a Chinese smart watch with basic features and the ability to make calls. These can be as cheap as $10! (Yes, you read that correctly!)
90 Questions View all
How do I fix the Charging Error?
My smart watch charges for about a minute then a message pops up saying "charging error", then the watch siezes to charge . How do I go about repairing that ?
Score 7
5 Comments
Not open my smartwatch place open my smartwatch dz09
by
When my smart watch on it says in a few seconds later “Charging Error” .But when i shutdown it it takes a lot of time but not a charging error DIALOGE
by
Shut on hni ho rha automatic shutdown
by
My dz09 smart watch ka charging pin demeg
by
My watch not switch on not charge
=== Update (10/10/23) ===
My dz09 smart watch not on not charge
by
Add a comment
Most Helpful Answer
Check the charging port to see if it has anything in it. It not the cost of repair is more than this watch is worth. I would just get anotherone.
Score 2
1 Comment:
it looks like a common problem just keep unplugging and re plugging it in seems to work on mine ,also after watching a video on you tube it may be play in the battery so just pop a piece of cotton wool on top of the battery and put the back back on may solve the problem .
by
Add a comment
Check that your charger and cable work.
Try them with another device.
Check that the cable is securely connected to the charger and to your phone.
Check that there's nothing in the port of your phone, like dust or lint.
Regards,
Peter
Add a comment
Add your answer
Joel Will will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 17
All Time: 5,876
