Released September 25, 2015. Model A1688/A1633. Repair of this device is similar to previous generations, requiring screwdrivers and prying tools. Available as GSM or CDMA / 16, 64, or 128 GB / Silver, Gold, Space Gray, or Rose Gold options.
1757 Questions View all
Unable to activate Touch ID on this iPhone
Hi, I’ve just tried to replace my rear camera. When I put it all back together and turned it on, it says I’m unable to activate Touch ID on my iPhone. I’ve tried disconnecting and reconnecting the Touch ID at both connectors (one at the home button and the other by the digitiser connector). This hasn’t made a difference. The home button has never been replaced and the Touch ID was working up until now. Home button still functions. How would you go about fixing this problem?
Score 3
Add a comment
Free shipping on all orders over $100 or containing a Pro Tech Toolkit!
Browse Our Store
Chosen Solution
You'll want to take a close look at the Home Button Flex cable that connects the Home Button, goes underneath the backlight shield and comes back out at the top of the screen. If the flex has a light tear or if the connector is damaged, it will impede the TouchID from functioning properly.
Unfortunately, if that's the problem, the only way to fix it is to replace the screen assembly.
Score 4
Comments:
I've tried changing the flex cable from the home button, but it still doesn't work. What should I do?
by
Add a comment
You have damaged the flex cable for the Touch ID sensor or have damaged the connector on the board. Replace the connector and tell us whether it works or not.
Comments:
Replacing the screen worked fine and the Touch ID works again. Thank you for helping!
by
No problem,mate,glad to have helped!
by
Add a comment
Several Apple users offered their suggestion on Apple forums that turning the password off for Touch ID could have this issue fixed.  You could also restore your iPhone with iTunes. For more details and measures, you can check the article on '''Unable to Activate Touch ID on this iPhone''' Fix.
Add a comment
Add your answer
Alex will be eternally grateful.
Past 24 Hours: 17
Past 7 Days: 143
Past 30 Days: 698
All Time: 10,591
