I cant take out the screws on the back
i was trying to fix my 2ds screen when it works but when i took the battery out i found out the screws were impossible take out
It should be a standard phillips screwdriver. if the screws are not turning, they may be stripped, or you may be using a driver that is too large.
yep,they are stripped :/ I was using a 000 Philips screwdriver
if you absolutely need to get them out, it will damage the frame, but you can use a cutting disc attachment on a dremmel to cut a slot into each of them, and use a slot driver to remove them.
thanks.that fixed it!
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 18
All Time: 1,564
