Itunes cant recognized this iPod at the moment
Itunes displays this error message:
"Itunes cant recognized this ipod at the moment"
Weird?
Weird?
Try using different usb ports. All usb ports carry 5 volts. Not all carry enough current to charge your battery. If that doesn't work try a different cord. If that doesn't work look for debris or bent pins in your charging port. Remove any debris if found. If you find bent pins there is a replacement here. The replacement part requires soldering.
Left the ipod connected to itunes for some time and it installed "apple device" ! But still nothing showed up on itunes or my computer.
Btw does that connector fit 5th generation nano?
If the battery doesn't have over 3 volts it might not show up. The connector will fit a 5th gen Nano, but you have to add a 68ohm resister to one of the pins. The pin out to the connector is here http://pinouts.ru/Devices/ipod_pinout.sh... at the bottom of the page is what you need to know for the 5th gen nano.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 1,299
