Mid 2009 Model A1278 / 2.26 or 2.53 GHz Core 2 Duo processor EMC 2326
745 Questions View all
remove & replace keyboard from topcase
Hello,is it easy yo remove and replace the keyboard from the topcase ??only needs to unscrew the screws ?thank you.
Score -1
1 Comment
i have already this manual.it does not refer about the removal of the keyboard from the topcase,only says for the removal of the topcase..
by
Add a comment
Chosen Solution
Here is the guide to do so, and here is the part.
MacBook Pro 13" Unibody (Mid 2009-Mid 2010) Upper Case Image
Product
$49.99
Score 1
Add a comment
Its not so difficult to remove the keyboard from the Top Case. just remove the logic board and dvd rom. then remove the keyboard light sheet then remove the plastic shielding for the keyboard in which leds are inserted. then you will see a lots of a small screws. near about 25-30 approx. and unsrew the power on/off screws. then you can ready to change the whole keyboard without changing whole top case ...
Score 1
Add a comment
Unfortunately you cannot remove the keyboard itself from the topcase without breaking it. If you need to replace the keyboard for whatever reason, then you need to replce the Topcase itself. Refer to rab's answer above to remove and replace the topcase.
Add a comment
BUt HOW DO YOU PUT IT BACK TOGETHER AFTER TAKING IT AND THE 40 SCREWS OUT?
CAN YOU?
1 Comment:
Well - in reverse order, obviously.
by
Add a comment
Add your answer
panos will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 8,679
