The Sennheiser RS 120 is an RF wireless headphone system with open, supra-aural headphones.
Getting into the Sennheiser RS-120 Charging cradle
How do you take the front plate off a Sennheiser RS-120 charging cradle? The covering on the RCA male jack wire to the cradle has decomposed and needs replacement. Easy to do if you can get inside the box. Doing so is the puzzlement.>
Add a comment
1 Answer
Most Helpful Answer
First remove the two small screws that are visible on the back panel. Then **carefully** pry apart the front grey panel from the black rear panel. The plastic is designed to clip together very tightly. Use a credit card or blunt knife. The bottom should come free first, as the top hooks into place. There are no other screws.
Score 1
Add a comment
Add your answer
Donald CE Ferguson will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 104
