Why does my iBook intermittently suddenly shut off? (continued)
So we replaced the old DC-in board, and it seemed to solve the sudden shut off when the computer is plugged in; however, the computer still seems susceptible to shutting off when running on battery. Stats from Coconut Battery make me think that a new battery will solve what remains from my issue. Here's the current read:
Current battery charge: 971 mAh
Max battery charge: 1205 mAh
Current battery capacity: 1205 mAh
Original battery capacity: 4400 mAh
Battery-Loadcycles:880
Age of your Mac: 75 months
Charger connected: Yes
Battery is charging: Yes
Comments:
This is a second problem this book had. It also had a bad DC-IN port that was solved: Why does my iBook intermittently suddenly shut off?
by
Add a comment
MacBook Battery Fix Kits
Fix Kits Starting at $69.99
Starting at $69.99
Chosen Solution
You never gave me the results of the Coconut battery till now. Your battery is only 27% of its original capacity. If it runs 20 to 30 minutes that would be about right. If you intend to keep your Book for several more years I would get a good replacement with a one years warranty.
iFixit is out of stock: iBook G4 14" Battery
But you can get a new one here: http://store.fastmac.com/advanced_search...
Score 1
Comments:
Thanks for all of your help - and patience! Apologies if I let bits and pieces of info out too slowly. I wasn't sure what would have been relevant at the time, so I thought I'd try my best not to confuse issues.
by
Add a comment
Most Helpful Answer
Your battery seems to be pretty old. A new one will probably solve your problem.
Score 2
Comments:
Thanks. I just didn't expect that battery age/wear would prevent the iBook from going to sleep properly when battery power goes low.
by
Add a comment
Add your answer
jtsantos7 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 937
