7.9 inch display / Model A1432 / Available in black or white / Announced October 23rd, 2012 / 16, 32, or 64 GB capacity
220 Questions View all
Replaced logic board and now the device will not charge
I received an iPad mini from an aunt who had broke the LCD + Digitiser. I replaced those but the digitiser did not recognise touches, I realised that the connector was missing pins on the logic board so I bought an iPad mini with a cracked screen on eBay.
I replaced the cracked screen with the ones that I bought and it worked perfect, but the case was bent really bad so I decided to move the logic board from the working iPad mini into the case of my broken iPad mini.
I done this earlier today and I was extra careful, and thought everything went smoothly, after closing everything up I decided to try the charger, but nothing. No charging indicator or noise. Im not sure what the issue is, I didn't rip the flex or solder points as I was extra careful, but it just doesn't recognise the charger when inserted and doesn't take on any charge.
I haven't opened it up again to have a look but are there any suggestions as to what I should double check when I do?
edit* Okay, some more info I've discovered since I posted this.
  • 99% of the cables + wall adapter combinations I have tried will not work (iPad displays the not certified message), even the official out of the box Apple ones
  • iPad charges with only 1 or 2 cables out of the pile that I had tried
  • From the cables that do work, they dont work both sides (meaning if I put it in and it doesn't recognise the charge I have to turn it around to the other side and it'll work
  • The 1 or 2 cables that I have got to work are unofficial apple ones
Add a comment
1 Answer
Chosen Solution
I would closely inspect the flexes for tears, even small ones and the areas on the logic board surrounding the connectors for loose or dislodged components.
When you connect your iPad to an iTunes enabled computer, is it recognized? If not, try another cable if you have one and reboot the computer/iTunes to be certain. A failure here could point to a problem with the charge port or logic board.
Score 2
5 Comments:
Okay, so something strange just happened. I plugged it into my laptop like you said and it was recognised + started to charge, but when I tried my wall adapter it doesn't charge.
Edit* Also checked with portable power bank and it charges through that.
by
Your wall adapter may be defective. Try other ones to see if you can isolate the problem.
by
Tried multiple wall chargers, all with the same issue. I just realised that when the iPad is locked and plugged in via wall (official apple wall plug + lightning cable) I get a message saying that the charging accessories are not supported or something along those lines. Tried with 3 official cables + wall plugs.
by
There may be an issue with the charging circuit, specifically the Tristar IC. Can you do a backup via itunes?
by
Yes I can. It can connect to iTunes just fine via the laptop
by
Add a comment
Add your answer
brandan McDevitt will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 211
