Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
iPhone 6 Stuck Itunes Logo (Error -1)
Hye i got an IPhone 6 sent in to me for repair. It stuck on Itunes logo and when I do recovery it showing Error -1. Before this the phone having a NO SERVICE issue, and then when the customer do recovery on itunes, it begin to stuck on itunes logo. When I hunt around the baseband area through microscope, I see two caps are missing (C4103/C4104) . I believe that this two caps are responsible for WTR_TX_OUT line.
So my question is, can I just make a jumper on this two lines without solder a new caps ?
Add a comment
1 Answer
Chosen Solution
You can't jumper capacitors, that's not how they work. These particular caps are used inline, that means they are meant to filter out any DC component to the AC signal going into U_2GPARF. These are pretty standard capacitors and easy to source as new or from donor boards.
Do you believe these capacitors were removed by another tech or were physically damaged? Check closely to see if anything else is missing. As for Error 1, I would reball the baseband CPU.
Score 2
2 Comments:
I dont think the caps is been removed. Maybe because of the physical damaged. So what about the BB PMIC ? Do I need to reball ?
by
Start with just the BB CPU.
by
Add a comment
Add your answer
Azim WHITE will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 3
All Time: 73
