Mid 2009 Model A1278 / 2.26 or 2.53 GHz Core 2 Duo processor EMC 2326
838 Questions View all
Screen not showing red color at certain angles. Where to look?
Hi,
my right hinge is totally broken on my mbp. However, the screen is working but is, with the lid at certain angles, not showing red color. (Replaced with black). Something like this;
At 10 degrees (almost closed lid) to approx. 70-80 degrees: working good, showing RGB.
At approx. 70 degrees to fully opened: only showing green and blue channels.
Anyone have a suggestion on where to look?
Thank you for your time!
Chers,
Johan
Add a comment
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
1 Answer
Chosen Solution
I would give up using your LCD and use an external monitor until you replace the hinge. After that you will need to replace the video cable. The wires on it obviously are broken internally. The gist of both of these repairs in is this guide.
MacBook Pro 13" Unibody Mid 2009 LCD Replacement
Score 3
Comments:
I have nothing to add +
by
Agreed. Its a fairly simple task to replace on of these. Done it on many occasions. Good Luck!
by
Okay, thank you both for your time! I will follow the guide.. Wish me luck! :)
by
Add a comment
Add your answer
Johan will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 870
