Model A1311 / Late 2009 / 3.06 or 3.33 GHz Core 2 Duo processor
243 Questions View all
iMac a1311 wont boot, it chimes, but freeze at apple logo.
iMAC wont boot at start up, freeze at apple logo. I try to boot using system installation CD, optical drive spins and read the disk but when the apple logo appears... it freeze. I tried to replace a new harddrive and boot again using the system installation CD but it freeze at apple logo. I even tried replacing the both RAM with new one but still it freezes at apple logo and i can boot the computer. pls help. This is an A1311 3.06 Ghz Core 2 Duo machine.
Comments:
I don't know if you know the correct procedure for start up from a CD so I gave it.
by
Add a comment
1 Answer
Chosen Solution
Insert your system installation disk and start up holding down the "C" key. Go to the second screen pull down menu to Utilities -> Disk Utility. See if the drive shows up on the left hand side. If so then see if it can be repaired.
Comments:
,yah, i know the procedure how to boot using system installation CD...im pressing/holding "C" at start up..
by
Add a comment
Add your answer
Cled Tayamen will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 18
All Time: 4,641
