What equipment is needed to safely and correctly remove HDMI & GPU
what is the best desoldering equipment needed to safely and correctly desolder and resolder ps4 hdmi and reball cpu/gpu
Score
0
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 245
Hi Tech Neek, what issues do you think you need to reball the cpu and gpu?
I would say this is a challenging job, you need proper tools and equipment,
reballing a ic need patience, e.g. heat stencils, or unless you have the new one with bga balls ready.
and also desoldering wick and good flux like amtech ..... to clean up those old soldering mess.....
Before you proceed
if you are unsure, test with a scrap board before testing up,
there are many ways...... on youtube, i have a 2000w hot air blower, smd rework station, soldering station,
Important: Take out cr2032 button battery before desoldering!!
note on the temp on de-soldering the ic ... cannot be too high or too low...
normally i will construct a board with aluminum cover and cut of the square part to expose only the surface of the bga ic to be removed... this is to prevent the heat from affecting other components and misc....
and note of those smd components, not to knock them out.. else a big headache to put them back....
by Augustine
i have heard that the only way to repair a PS4 with BLOD is to reball it so i am doing some research on the correct equipment needed to do so and also removing HDMI ports i have tried using a 480c hot air rework station to no avail.
by Tech Neek
