Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White.
3238 Questions View all
What are the symptoms of water damage?
Hi, recently i had accidentally spilled a whole cup of ice green tea latte on my iPhone. I immediately cleaned off as much liquid as i could and the iphone seemed to be functioning fine. ( For the next 4 hours)
However, after charging the phone and unplugging it, it suddenly became very hot(approx 60 degrees celcius) and the battery drained extremely quickly. I was watching the phone and it was dropping 1% perhaps every 20 seconds. I had made sure to turn off all back ground tasks, wifi and 3g, but it was still getting very hot.
Even after turning off the phone, the bottom left area of the phone stayed at the same temperature for about 1 hour, which is really making me concerned.
Could the liquid have somehow screwed up the battery and caused it to drain and produce lots of heat very quickly?
Add a comment
1 Answer
Chosen Solution
Yes it could and before going any further, I would most certainly disassemble the phone and clean it with my favorite, isopropyl alcohol and clean all corrosion and debris. After that I would DEFINITELY replace the battery and re-evaluate from there. ALWAYS LET IT DRY AND DISASSEMBLE BEFORE TRYING TO TURN IT ON.
Score 1
Add a comment
Add your answer
Wai Soong will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 12
All Time: 5,011
