The Acer Aspire E 14 Touch can be identified by its model number: E5-471-5456. The device was released in late 2014 and has a 14 inch HD LED-backlit TFT LCD display, a NVIDIA GeForce 940M GPU with 2GB DDR3 VRAM,  as well as an intel core i5 processor with 2.2GHz.
1 Questions View all
I spilled a few drops on the keyboard and 1h later some keys dont work
Well anyway I somehow got a few drops into the keyboard, and a hour later keys 1,3,-,q,t,u,p,],and j stop working simultaneously. This happened at around midnight so I was brain-dead and waited a hour before I thought of turning it off and unplugging it(i need to unscrew the battery). I hope I can somehow get it to work again.
Add a comment
1 Answer
Most Helpful Answer
If it is just the keyboard, then try cleaning with a clean cloth dampened with alcohol or Q-tips with alcohol. If the spill got onto the system board, you can try taking the laptop apart and also clean with alcohol. Since it has been a short time since the spill, you should look for whitish residue or water marks on the system board. You should also check the keyboard connector. good luck.
Score 1
thanks man, if this works you just saved my laptop
its spreading, here is a list of letters that still work:abcdefghnrsvwxyz (17/26, 9 broken)
now for numbers:2456 (4/10, 6 broken)
special characters: `=[\', (6/11, 5 broken)
btw i can use the i key to left-click
the broken keys has gone up 185% after 3 days, I haven't opened the inside yet
Add a comment
Add your answer
INeededA_Name will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 15
All Time: 15
