just shut off by itself.
I have the the 2011 Panasonic TC-P42S30 Viera plasma TV that just shut off by itself. At first the red light was blinking 12 times in sessions. I tried all the advice I read above. Nothing has worked. I even unplugged it for a night. and tried the above, Nothing. :(
Any other advice????? 3/2018
8 Comments
Did you get your t.v. fixed ? What was wrong please ?
by Jo Grice
I fixed it.
I had to Frankenstein my tv though. I took off the plastic panel, after unscrewing all the back screws. My Panasonic Viera would flicker on the bottom left side before it turned off. So, I went under that bottom left side after taking off the panel. I ripped out the speaker. Then, there’s a jumble of wires that runs to the blinking red light in front. I took that out. Since then, tv works.
Looks like a Frankenstein tv though. I ripped off the panel.
by Albert Winston
The comment above does not pertain to my TV I put the TV on it stays on for a few minutes and then goes off when I try to turn it on again it stays on for a few seconds and then goes off again I just can't get it to stay on and I just put in a new lamp
by ldlady883
is it worth fixing? I just paid over $100 for a new lamp
by ldlady883
Hi @ldlady883,
I was just curious if you ever found out what was causing the issue on your TV. I have the same problem as you - i.e. The screen will completely turn on for 2 seconds then turn off.
Once it turns off, the red “remote” light on the bottom left of the TV will blink once every 4 seconds indefinitely.
Cheers,
David.
by David M
Show 3 more comments
