First generation Apple iPad with Wi-Fi, available with 16, 32, or 64 GB. Model Number A1219. Repairs are straightforward and do not require heat.
129 Questions View all
My iPad will not fully restore itself? Itunes stops short.
My ipad syncs with itunes and itunes starts to restore it's software as it's should.But itunes gets almost to the end and stops. Can anyone help. thanks, chiob12002@yahoo.com
Comments:
When u say it stops; do u get any error messages, or does it just freeze?
by
it jest freezes jest befor completion.
by
Is ipad fully charged??
by
Add a comment
MacBook Battery Fix Kits
Fix Kits Starting at $69.99
Starting at $69.99
1 Answer
Chosen Solution
Are you trying to restore an older firmware? Such as 4.2? You need to restore the current firmware on the iPad (And other 3rd Generation+) devices, (Apple's way of preventing downgrading) You can download it here and install it by shift-clicking "restore" in iTunes, and selecting the file. Also, if the file you downloaded has a ".zip" extension, do not extract it. Change it to ".ipsw" and iTunes will reconize it.
Score 3
Comments:
+ why won't it open the zip?
by
I believe that the web browser changes the ".ipsw" extension to ".zip" automaticaly. iTunes will not open the .zip file, and extracting it will simply extract the contents of the firmware update file. You actually have to rename the file yourself, for iTunes to accept it.
by
Add a comment
Add your answer
chiob12002 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 1,746
