2.5 GHz dual-core Intel Core i5 processor (Turbo Boost up to 3.1 GHz) with 3 MB shared L3 cache.
180 Questions View all
Water on my laptop, doesn’t power on
So it’s sunday morning and I accidentally spilled water on my keyboard. It wasn’t that much water so I tried to wipe it off and continue using my laptop, I didn’t turn it off and no, I didn’t unplug it (I know it’s stupid). It worked for a few minutes but it turned off after that, and I can’t turn it on at all now.
What can I do?
Comments:
It just turned on and everything seems to work fine. Do you think I should turn it off and leave it for a few hours?
by
no. water damage will eventually kill your laptop and it will be harder to repair then. as time goes on, the corrosion keeps increasing until it shorts something. and once that happens, that will be expensive.
by
Add a comment
Chosen Solution
Oops! water damage is never fun to deal with.
This guide will help you take it completely apart,
MacBook Pro 13" Retina Display Late 2012 Upper Case Replacement
The upper case does not need replacing, this guide is just pretty close to a disassembly.
and then you need to remove any water with help from this page:
Electronics Water Damage
you also must replace the battery.
MacBook Pro 13" Retina Display Late 2012 Battery Replacement
MacBook Pro 13" Retina Display Late 2012 Battery Image
Guide
Difficulty:
Difficult
30 minutes - 2 hours
MacBook Pro 13" Retina Display Late 2012 Upper Case Image
Guide
Difficulty:
Difficult
2 - 4 hours
Add a comment
Well... Not good!
At this point you're likely going to need to replace some parts like the uppercase and/or logic board. Leaving the system wet corrodes and shorts out components.
You might want to let someone with deeper skills repair your system.
Add a comment
Add your answer
Nicoleta will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 70
