Installing hard drive for MacBook Core 2 Duo
Can I install 2TB SSHD in my Macbook Core 2 Duo?
Sadly, you can't install a SSHD as there is no SATA II (3.0 Gb/s) compatible SSHD.
You can install a SSD into your system. But before you go with such a large unit keep in mind the age of your system. App & OS support is limited with what you currently have. While you can re-use your SSD in another 2.5" based system or external drive case I would recommend sticking with a 1 TB drive.
Here's the IFIXIT guide you'll need to follow: MacBook Core 2 Duo Hard Drive Replacement As to what drive to use you'll need to get one that supports SATA II (3.0 Gb/s). I would recommend going with a Samsung 860 EVO You notice in this spec sheet SATA II is supported. Whatever you go with make sure the spec sheet lists SATA II (3.0 Gb/s)
What's the cheapest 1TB SSD can I get?
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 53
