The Mac Pro First Generation is an Intel Xeon-based workstation computer manufactured by Apple Inc. The first generation model includes the machines from 2006 through 2008.
317 Questions View all
My mac pro is showing in the hardware-selftest a failure with memory,
Hallo Community,
after starting my mac Pro 3,1 , the (self-testing) hardware-test is showing a failure, although the machine is running quite normal. Inside there are 6 memory -blocs. When looking into the deatailed test, the DIMMS are all ok.
Here the original german message:
Selbsttest beim Einschalten:
Zuletzt ausgeführt: 08.03.18, 10:50
Ergebnis: Fehlgeschlagen
Fehlerart: Speicher
Speichersteckplatz: 140371258646535/140371258646542
For testing purpose I changed the four discs against a clean and simple running system with Os X 10.11.6 but the same result.
I would be very happy, if somebody could give me an advice!
Thank you very much in advance,
wolfrob
Add a comment
1 Answer
Chosen Solution
Hallo,
now I can give the answer myself.
I checked each DIMM in single pairs by starting the machine again and again. At the end one DIMM showed a failure. After having installed the DIMMs following the official plan, my MacPro is running now without a problem.
Thanks for reading...Everything is ok. now!
wolfrob
Add a comment
Add your answer
Wolfrobbe will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 57
