Car makes.grinding sound when I am in gear
I have 89 honda acord I think it is clutch plate. Car makes.grinding sound when I am in gear 1 is ok pops out.2 same 3 only makes sound when I exselrate and so on. 170 k I can't go in to reverse. Where do I start. Some one said I should adjust cable arm. No leaks no burnt oil smells. Looking for the cheapest fix
Update (03/08/2018)
So continue to take transmision out. Found out why reverse did not work. Most of all found out most of noise.5th gear was completely grinded down. And bearing that go to casing was broke. Could this be my problem. Can.i just repair 5th gear and bearing without taking transmission out
