Water Spots on Screen, New LCD needed?
Hey, I spilt some orange soda over my 64GB itouch, and instantly went to flush it out with 90% isopropyl alcohol to get as much as I can off and out of any cracks or crevices. I successfully got the soda out, but some of the alcohol left these "bright blotches" on my screen. When reading on other forums, etc. I heard that it should evaporate and go away in a few days. It's been 3 weeks, and they're still there. If I open this up, could I let it air out or otherwise remove these markings? Or did I irreversibly damage the LCD screen?
I included pictures to show exactly what happened.
Comments:
Did u find an answer anywhere??
by
Hi, do you find any solution for your problem?
by
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
The spots will not go away this is from water damage. If it bothers you you can replace it. I would wait until it fails or the glass gets broke to change it out, that way you dont damage the screen removing it.
Add a comment
First I would try opening up your iPod, and using a micro-fiber cloth to see if they will come off. If not, then you will need a new LCD which is not that expensive. Usually under $25.
Add a comment
Add your answer
Michael Dornisch will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 5
All Time: 2,164
