System freezes and also get folder with question mark
I actually have an A1466 model of air. A few months ago if started freezing either on startup or while your using applications, very random. I am forced to press power button to shut down and restart. On startup it will come up with symbol of folder with question mark. I have ran some test and it showed a code which talked about memory problem. Finally got a new logic board and swapped it out on the advice of an IT friend. After putting everything back to together and started up it froze again. Forced a power off and restart. On restart I received folder with question mark. My question is what next the SSD or another logic board. Suggestions please.
2 Comments
Did you ever figure this out? I have the same model and the same problem. The computer will be acting normally and suddenly freeze. Upon restart I get blinking folder. After another restart generally it loads normally. Not sure what is going on but it seems random, meaning I can’t discern what is triggering it. It’s happened twice and both times I was in my browser.
by Mikem
@danj is this possibly the same issue with the APSF?
by mayer
