The PlayStation Vita is the successor to the PSP. It contains a beefed up processor and graphics, and includes the addition of a second analog stick. It was released February 15, 2012.
165 Questions View all
not taking a charge or powering on.
My PSVita will not take a charge or power on I bought it from a pawn shop a while back and it would not do anything and they would not take it back what might be the problem and how would I fix it.
Score 1
1 Comment:
So I will get a new battery as soon as I get the money what is it like $15
by
Add a comment
@fatedengram this can be an issue with the charger, the charging port and/or the battery. Use a multimeter and check your charger to make sure that it has the proper voltage output (5V). If that is okay check the power port and change the battery while you are at it. Use these guides PlayStation Vita to work on it.
4 Comments:
I will need to buy a multimeter then to test them.
by
i tested the battery and the charger the battery im getting 2.82 and i tested the charger connected to the motherboard and im getting.14 with the wall outet .02 with the usb plugged itno my laptop if i tested correcctly.
by
@fatedengram "the battery im getting 2.82" start with a new battery. Not sure where you tested for the voltage on your port but either one is to low.
by
I disconnected the battery from the motherboard and tested the connector
by
Add a comment
Try opening it and unplug battery and plug back in then charge it. Sometimes that can fix. If slim model the android style charging cables are junk and often go bad. So it maybe your charger.
Add a comment
Add your answer
Jake Romine will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 18
All Time: 1,627
