cable from wifi board to main board is broken
my macbook pro 17 early 2011 does not recognize wifi card.
i have changed wifi card and says the same. because i have a macbook pro 13 late 2011, i have test the wifi board on both mac, and only works on mbp 13. but i have changed the cable from wifi card to the main board card from the mbp13 to mbp 17, and then works.
so, i can see that what does not work from the mbp17 is the cable, not the wifi card.
is it possible to replace it?
Actualización (05/03/18)
that's the cable that does not work. does ifixit sell this product?
1 Comment
Lets back up here a moment... You have two statements which can't be correct. The MacBook 17" model uses an Airport card thats mounted in the clutch cover and the MacBook 13" late 2011 model uses a different Airport card which is mounted just behind the optical drive under the bottom cover. The connections are different so you couldn't plug one in for the other.
by Dan
