What kind of logic boards will work?
ibook g4 1.42 A1134
I have a Ibook g4 14" 1.42 GHz what kind of logic boards would be compatible or for upgrading ?
Add a comment
MacBook Battery Fix Kits
Fix Kits Starting at $69.99
Starting at $69.99
Chosen Solution
This was the last iBook made so you already have the top end machine. Here's the logic board: iBook G4 14" 1.42 GHz Logic Board
Score 4
Comments:
So this is the only logic board that will fit in this computer?
by
Apple iBook G4/1.42 14-Inch (Mid-2005 - Op) Specs
Identifiers: iBook G4 - Mid-2005 - M9848LL/A - PowerBook6,7 - A1134 - N/A
by
There is only one logic board for this machine no matter how many times you ask.
by
Add a comment
This answer was originally to another question.
If your machine will start up, go under the Apple to "about this Mac" more info Hardware. This will tell you about your logic board. If you give us the last three letters of your serial number I can tell you what the logic board should be. Also look in the battery compartment for your processor type and serial number.
Score 2
Add a comment
No you cannot replace the 1.33 GHz logic board with a 1.42 GHz one. Hard drive set up, airport card socket, inverter socket, reed switch board location, track pad are different so no you can't swap.
Score 1
Comments:
+ I got so busy answering the first half of the question I missed the second part ;-)
by
Add a comment
The late 2004 1.33ghz logic board is not compatible with the mid 2005 1.42ghz iBook and vis-versa. The logic boards of those iBook doesn't have same layout. The airport card is an "user" add in option on the late 2004 but not on the mid 2005 which is a standard feature with the bluetooth.
By the way, I have on my workbench a mid 2005 iBook opened and the airport card seem to cause kernel panic. The KP is resolved when the airport card is unconnected to the logicboard. I'll try the plastic spacer trick which consist to put an little piece of plastic in between the airpot card and the retaining bracket which retaining it close to the logic board.
Add a comment
Add your answer
roaddog10 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,175
