Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 16 or 32 GB capacity / black or white plastic back.
1958 Questions View all
power button flex cable came off
Hello,
repairing a 3GS from a friend who has dropped it. power button was working only when pressed very hard, then stopped working at all.
Took it apart and the flex cable came off the black plastic power switch housing. Is there any way to get it back in or do I have find the whole ribbon cable assembly and replace it? That would include all the other button connectors like volume etc., a major hassle.
Also noticed that the FFC only has one single connector to the switch? Does the switch ground it to the chassis then?
Thanks in advance,
heinz
Add a comment
1 Answer
Chosen Solution
The powerswitch ribbon is connected to the audio jack, volume, and silent switch. This connects to the #5 connector. To repair this, you need to remove then entire ribbon assembly and replace with a new ribbon. Which means, remove board and remove ribbon assembly.
Add a comment
Add your answer
heinz will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 2,929
