The cable won't connect
I did a screen replacement on my iPhone 6+, and the cable in the photo: https://imgur.com/tPbQQzr
Won't connect to the phone. What can i do?
Hi Tomer,
If the connection on your motherboard isn't mashed or damaged then you should have no problem plugging this cable in.
You could be attempting to plug the cable into the wrong socket on the mainboard, a mistake I see trainee's making when doing iphone 6 repairs and not putting the cables in the right spot.
The cables should not sit behind each other, and will all neatly line up to where they're supposed to plug in.
Try tucking the speaker flex cable behind the screen cables, or visa versa.
Good luck!
~S
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 63
That's the front camera sensor yeah? Is it all original cables? or have you replaced any
by Will91491
Original one, the camera worked before i did the repair
by Tomer
