Repair information and guides for the Apple iPhone 5c that was announced on September 10, 2013. Model: A1532, A1456
1233 Questions View all
volume up not working
i have dropped this phone a few times and n ow the volume up button is jammed in and doesn't work at all. If i replace the buttons, will that fix the issue or will i need to replace the audio/volume cables too?
Add a comment
Chosen Solution
As suggested by Will, you can try to take the volume button out to see if it will fix. However, if this does not work, you may have to replace the button. Luckily for you, Apple has created a software where you can tell your phone to do things, without touching any physical buttons. This is called Assistive Touch, which you can easily enable in your settings app. Here are some way to get to assistive touch.
Go to Settings > General > Accessibility > AssistiveTouch, then turn on AssistiveTouch.
Tell Siri “Turn on AssistiveTouch.”
Go to Settings > General > Accessibility > Accessibility Shortcut and turn on AssistiveTouch.
Once you have turned on assistive touch, you should see a small black square with a white circle in the middle. You can move this to any side of your screen and one tap on this button will open up many different options that you can ask your iPhone to do. The volume up button that you are looking for is in the "device" icon. The volume up and down buttons are located in here, which you can use just by pressing on either button.
Hope this helped,
Nathan
Score 1
1 Comment:
I had same problem but I just switch off and after 2-3 minutes do switch on then it's working thanks
by
Add a comment
Most Helpful Answer
You may not even have to replace it, if you can take the Volume down button out and insert it back into the side if may work. Otherwise you could just replace the button itself, the flex should be fine so long as you dont damage it getting it out
Score 1
Add a comment
Add your answer
Tracy Rivera will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 1,203
