Released September 25, 2015. Model A1688/A1633. Repair of this device is similar to previous generations, requiring screwdrivers and prying tools. Available as GSM or CDMA / 16, 64, or 128 GB / Silver, Gold, Space Gray, or Rose Gold options.
1661 Questions View all
Battery charge dying too soon
My iphone 6s fell down accidentally n the screen broke. Later i gave it in a store which fixes these issues(not apple store).gt the screen replacement done but the battery shows the same 3% charge evn after charging for few hours. Wat can i do now? Pls help me figure this out!
Add a comment
Spread Fixmas Cheer
Get $12 off your purchase of $50 or more with code FIXMAS12
Spread Fixmas Cheer
Chosen Solution
QUESTION: Did This Happin IMMEDIATELY after receiving the phone back? or did the device work properly for a couple weeks before noticing the issue?
ANSWER:
NO: if the phone was working properly for a bit after the repair, it is highly likely that something else is causing your second issue.
YES: if the phone immediately has issues, then go in for a consultation at your local repair shop. any technician worth their salt will warranty a problem that has occured due to their neglegence.
QUESTION:: Did your phone work prior to the screen replacement. (Could you operate the phone in a normal manner, and read the battery % after the damage occured to the device?)
ANSWER:
NO: There is no evidence it was due to tech error, and was likely caused by the impact of the device. boardwork is likely required, and i suggestgetting it to a SMT specialist.
YES: It is high probability that it is a tech error. take it back to your repair center for their quality warranty immediately. the longer you wait, the less likely they will be inclined to beleive it is from them.
Score 2
Add a comment
Thank u and i gave it the store guy immediately after finding the problen
Hope ill be getting it back in a gud condition :)
Comments:
alrighty. well, im glad i could give you a solution to your question.
by
Who knows. As long as it isn't some cheap quality aftermarket screen the backlight circuit for the phone shouldn't blow up.
by
Add a comment
Add your answer
Rithika will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 52
