1.83 GHz Core Duo or 1.83, 2, or 2.16 GHz Core 2 Duo A1208 (EMC 2104/2110/2114/2124)
257 Questions View all
After replacing the hard drive, the LCD lights but shows nothing.
Disk Utility indicated mechanical failure in the iMac internal hard drive: "back up everything you can." I installed a new hard drive, but when I turn on the iMac I immediately got a solid white screen.
I booted from an OSX install disk, but still got the same solid white screen.
I started it up in FireWire target disk mode, connected to a MacBookPro. Using Disk Utility on the MacBookPro, I was able to eject the OSX install disk from the iMac. I was also able to successfully install OSX Snow Leopard on the new hard drive in the iMac. But even in target disk mode, the iMac screen remains white - no blue screen with yellow target disk icon.
Now the iMac boots up fine, I hear the "Welcome to OSX" music (doot doot da do-do) but the screen is solid white.
I reset the parameter RAM 7 or 8 times. I've checked all cables inside the iMac. I booted up in safe mode and verbose mode. Always the same result - everything works, but nothing appears on the iMac screen - no spinning startup wheel, no question mark, no text in safe mode. The display lights up, but nothing appears on it.
Add a comment
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
1 Answer
Chosen Solution
Unplug all peripherals, unplug the machine, press and hold the power button for 10 seconds. Plug it back in and give it a try. If this fails, plug it into an external monitor to try to isolate the problem.
Score 3
Comments:
Unplugging everything and following the above steps: no change.
However, I finally obtained a MiniDVI to VGA adapter, and the remote monitor works fine.
The main screen is still solid light gray all the time...
I appreciate your help!
by
Add a comment
Add your answer
mickman will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,775
