Released on July 21, 2011. Core i5 or Core i7 Processor. Thunderbolt. This unit is also used to run the Mac mini Server configuration.
204 Questions View all
upgrade ram mac mini server (mid 2011)
ho un mac mini server (mid 2011) con 8gb di ram, è possibile aumentarla a 16gb? se si quale è la migliore?
1 Comment
I have a mac mini server (mid 2011) with 8gb of ram, you can increase it to 16gb? if which one is the best?
by
Add a comment
1 Answer
Chosen Solution
Standard RAM: 4 GB Maximum RAM: 16 GB*
Details: By default, 4 GB is installed as two 2 GB modules.
*Officially, this model supports 8 GB of RAM, but as first discovered by OWC, it actually is capable of supporting 16 GB of RAM using two 8 GB modules.
RAM Type: PC3-10600 DDR3 Min. RAM Speed: 1333 MHz
Mac mini Mid 2011 RAM Replacement
Score 4
4 Comments:
hi, the ram for mac mini mid 2011, can we use 1600 PC3-12800 - does it need to be low voltage model ?
by
This model uses:
Details: Supports 1333 MHz PC3-10600 DDR3 SO-DIMMs.
by
noted on that, but do we have to use DDR3L or normal DDR3 ? thanks
by
Either will work!
The L is for low voltage option. This RAM will work in either normal or low voltage systems.
by
Add a comment
Add your answer
massimo mignogna will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 895
