Green splotches all over the screen, what could be the problem?
bold textWhen I turn the TV on I can see green before the channel comes on. When it comes on I am getting green splotches all over the screen. Any ideas what the problem could be?
Update (02/24/2018)
Also it is a Samsung LN46D630M3FXZA
11 Comments
Does it look like ectoplasm? https://www.tribality.com/2018/01/26/the...
Do you live in a very high humidity area?
by mayer
The other colors are there but the green splotches are there, sometimes more sometimes less. There is high humidity now because it is winter but most of the time it is dry.
by Skip
@skippy1949 add some pictures of what this looks like with your question. Use this guide Adding images to an existing question for that. It will allow us to see what you see. You also want to verify that you TV is a Samsung LA40R81BD
by oldturkey03
I posted some pictures.
by Skip
Hi @skippy1949 ,
Try a 'power reset' just to check if it is corrupted data that is holding some settings on.
Turn off the TV, turn off the TV wall power outlet, disconnect the TV power cord from the outlet, press and hold the TV power button for 30 seconds and release.
Reconnect the power cord and switch on the outlet then switch on the TV and see if the problem is still there or not.
by jayeff
Show 6 more comments
