Released September 16, 2016. Model 1660, 1778 Available as GSM or CDMA / 32, 128 or 256 GB / Rose gold, gold, silver, black, and jet black.
598 Questions View all
Touch ID works but home button doesn't after repair.
Exactly as it says. I replaced the screen, and now the home button "click" doesn't work. It displays a message saying "the home button might need repaired" and brings up assistive touch. However, the Touch ID works, so I don't think it has anything to do with the screen. I have completely reset the phone in DFU mode, no luck. Any advice would be appreciated.
Add a comment
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
1 Answer
Chosen Solution
There is an IC on the HB flex that is very fragile. It is called U10 or the Turtle IC. It is a micro-BGA IC and the solder balls can be damaged/cracked when removing or manipulating the HB flex. This IC is there specifically for the "click" functions. It can be replaced but this is a micro-soldering repair...on a flex cable to0...and is not a DIY repair.
Score 1
Comments:
Minho is most likely correct, and I believe the people at mendonipadrehab.com may be able to fix it. They specialize in those repairs, but its definitely not cheap.
by
It's a pretty standard repair, most experienced shops can do it, myself included.
by
Add a comment
Add your answer
Bayn will be eternally grateful.
Past 24 Hours: 11
Past 7 Days: 45
Past 30 Days: 193
All Time: 411
