2.5 GHz dual-core Intel Core i5 processor (Turbo Boost up to 3.1 GHz) with 3 MB shared L3 cache.
189 Questions View all
installed new battery, doesn't display
installed a new battery, but it doesn't display.
Shows white battery icon with white X inside on startup, but after login there is no battery icon.
Doesn't even show the battery in coconut battery.
Did a SMC reset and P-RAM reset, neither worked.
Comments:
Where did you get the battery?
by
Add a comment
Free shipping on all orders over $100 or containing a Pro Tech Toolkit!
Browse Our Store
1 Answer
Chosen Solution
I've seen this before, double check the battery connection as sometimes it can be finicky and just need an extra little push or a re-seating, even when it looks and feels good. If that doesn't work I'd worry about where the battery came from and/or if its a defective part. If a different battery still doesn't fix the issue there may be a larger problem with the computer. Hopefully this help, Good Luck!
Score 1
Comments:
This!
Actually just unscrewed the screws for the battery and screwed them on really tight and it worked.
When I did it the first time I screwed in the speaker screws with barely any pressure and it caused a hairline crack on them (doesn't affect function though), so I guess I was a bit cautious afterwards and didn't screw in the battery screws tight enough the first time around.
Thanks!
by
Add a comment
Add your answer
jason will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 32
