Arport Etreme card not detected?
I have installed airport extreme card into my iMac and it does not recognize it. (I think that the Airport Extreme card has bluetooth)I need the bluetooth,to be able to use a Magic Mouse and Wireless Keyboard. I guess I could use a dongle but I don't think that will wake up the machine, and since I installed the card would like it to use the WiFi as well. Thanks
Score 1
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
See if the card is seen in your System Profiler. If so then run software update and see if it downloads airport software.
Score 2
Comments:
I checked System Profiler, I am not sure what to look for but I don't see anything about an Airport Extreme or WiFi or bluetooth.
by
go to about this mac > more info > Network > Airport and see if it sees anything
by
OK I found the Airport Extreme card listed with related numbers and info but it says it is turned off, how do I turn it on?
by
I just checked for updates and nothing helped, I updated Itunes, and a couple others but nothing helped the airport. Thanks for any help, I appreciate it.
by
Go to your hard drive > Applications > Utilities > AirPort Utility and run it.
by
Show 4 more comments
Add a comment
Add your answer
Kevin will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 995
