Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
Name of part (probably a battery connector)
ADDED THIS IMAGE. This is from the iPhone 6 logic-board replacement guide, step 23. The piece I am talking about is outlined in red. Its logic-board socket is circled in red. In the picture, the socket is detached.
There is a part that attaches to the bottom (near the home button) side of the battery. It is shaped like a swimming dinosaur and attaches to the logic board. It came loose from its attachment, and then within the part, it came loose from its bracket. I am trying to figure out how to put it back together, as there is a small silver tab that I don't know how to rebend.
If I order a replacement, I need to know the name. If I want to try to repair it, I need to know the name to find out what it should look like when installed.
My iPhone is my camera, so I can't provide a picture.
Below are two pictures of someone else's iPhone (not the same model, but it doesn't really matter here). Just concentrate on the area around the battery, not the circled part or other stuff. The black tape-y thing running along the bottom of the battery is the part that I'm talking about. You can't see the continuation of the part in the pictures, but the part continues up (using the orientation of the first picture) along the right side of the battery, and then it jogs over to the right to connect to a socket in the logic board; it connects not far below -- maybe a quarter of an inch -- where the person's finger-tip is pointing in the second picture.
The up-and-down segment is stamped 820-5038-A in white lettering.
4 Comments
I'm sorry, but between swimming dinosaurs and whatnot, I can't make a mental image of what you're referring to. Surely you know someone with a phone who can take a picture for you so that you can attach it to this question. That would help us help you.
by
sounds like hes talking about the taptic engine
by
Try to look through this link and identify the part or step in question?
iPhone 6 Logic Board Replacement
by
Thanks for the suggestion, Michael. The part doesn't appear by name in the Logic Board replacement, but in steps 22 and 23, you can see that its socket has been detached from the logic board and is perpendicular to its in-socket position. See the picture that I've added to the top of my question.
by
Add a comment
Most Helpful Answer
if you mean this then its the ribbon from the battery
Score 3
1 Comment:
Thanks! It looks very much like that, but there is an additional segment that runs along the bottom of the battery. I'll see if the whole thing shows up when I look for "battery ribbon" and the like.
by
Add a comment
You are best suited just buying a new battery all together. I've not heard of just refurbishing a damaged one due to the cost of replacement batteries starting out at about $10 up to $30 depending on battery and model.
Score 2
Add a comment
This serial number refers to a iPhone 6 battery. Just replace the battery and you will be ok. It does not refer to anything on the logic board, you are mistaken.
Add a comment
Add your answer
jsetear will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 484
